Ford 8830 extremely slow remotes
ford401
I changed all the hydraulic filters on the 8830, and now I have extremely slow remotes/they hardly move the disc up and down, it’s the same on all 3 sets. Did I get dirt stuck someplace? Does anyone know where to check first?
Sounds like an o-ring or gasket might have shifted out of place when installing the new filters that is blocking the flow. Also, double check that you used the correct filters.
same napa filters i took off of it. could be an issue with one of them i suppose.
do you or anyone know the correct CNH filter numbers for an 8830? messicks shows multiple options
You may have lost prime on your engine-mount pump.
