Ford 8N 12 Volt Conversion Electrical Help
kabar53
I decided to convert my 1952 Ford 8N to a 12 volt electrical system with electronic ignition. Does anyone know what size / rated diode I should use in the harness? I am installing a Delco Remy 10 SI alternator (3 wire-72 Amps, voltmeter, and a 12 volt ignition coil with 3 ohms internal resistance.
Thanks! Looking at the Radio Shack site the diode (276-1661)shows rated at 50 volt / 6 Amps. Another tread mentioned a 3 Amp diode in series. Would there be a benefit or potential problem with choosing one of these diodes over the other?
The reason I say use that one is there is no way you will reach 50 volts or 6 amps in the excite circuit and so it is over kill and I have used it for decades now and never had one go bad
