Jake Hollimon
The 1950 8N Im working has a lever on the left side in front of the clutch. I understand its the shifter for a not so common high/low range gear. Ive read that to shift this lever that, in neutral and clutch engaged, you pull out on the lever and then shift forward or back. The lever on my tractor WILL NOT pull out the amount that I understand that it should. Therefore it will not shift forward or back. Can any of you comment on why this would be? The manuals that I have dont even show this part or lever on the tractor, more reason for me to believe this additional transmission gearing was not very common. A little more of my understanding of this gearing is that this tractor has a normal range, and then the additional high and low range on this four speed, giving it 12 gears. Any help and guidance on the inability to pull out and shift this lever is appreciated. New member here. Thanks yall!
