Ford 8N hydraulic issue
jproefrock
I just bought a 1952 Ford 8N tractor with a 60" brush cutter. The 3 point will only partially lift the front part of the implement. If someone lifts on the back of the implement, it will raise all the way and hold it. I checked the fluid level, which was fine, but noticed the fluid was very milky. I changed the fluid and replaced with NAPA premium heavy duty tractor hydraulic & transmission fluid #85-405, as it said it meets M2C134D. The issue is still present, and if anything it made it slightly worse.
I removed the inspection plate with the dipstick and watched as I attempted to lift the implement. I can see fluid movement in the center of the pump and from what I have read that is good. However, I also see fluid movement toward the back of the sump. Is that normal, or could it be an indication of a leak? I also see a small stream out of the top corner of the pump.
Any suggestions on next steps to troubleshoot further? I can post a video if that would be helpful. Thanks.
(quoted from post at 12:50:29 08/14/10) I just bought a 1952 Ford 8N tractor with a 60" brush cutter. The 3 point will only partially lift the front part of the implement. If someone lifts on the back of the implement, it will raise all the way and hold it. I checked the fluid level, which was fine, but noticed the fluid was very milky. I changed the fluid and replaced with NAPA premium heavy duty tractor hydraulic & transmission fluid #85-405, as it said it meets M2C134D. The issue is still present, and if anything it made it slightly worse.
Investigate this one: " I also see a small stream out of the top corner of the pump. "
the utf fluid is thinner than the 90wt gear oil that was likely in there.. that's why the performance is worse.
as jmor said.. leaks from the pump chambers will need to be addressed. leads at the rear of the pump -COULD- be relief.
any leaks from the mouth of the cyl?
soundguy
