ford 8N shift problem
FWB in SK
Guy has Ford 8N on kijji Says this is problem the gear shift seems to be locked out of first and third gears is this expensive to repair Im interested in buying.
Whats the full story of it?? If it has sat a long time with out being used it could be as simple as driving t around a good bit to get the oil moving so the shift rail loosens up. I had that happen to an 8N I once had where it would only shift into 2 forward gears and reverse and I used it and after a few days of using it the other gears freed up
