So let me start with I'm a Deere guy. My Mm a local museum asked me to look at their 2n/8n. Front mount distributor. Was restored about 10 years ago, runs about 10 hours a year. New guy overseeing it and it won't start. Had a coolant leak from bad water pump. Got pump, starter switch replaced. Tried spinning over, it's sluggish. Battery is 8 years old, so it might be on its last legs too. To overcome that I put my big 6v jumper on and it spun decently. However it never pops, tries to start, just spins.
So I did a little reading and the wiring looks good per a drawing I found. I have 6.3 volts to the top post of the coil. The spark was very small and yellow/white
Given that, if reading other articles it seems like my next step to investigate would be to pull the coil, pull the cover and check points, shaft movement and make sure it looks good. Am I going the right direction?
