Ford 8N Steering
Andrewclark1
I have a 1951 Ford 8N I bought from an auction a couple of weeks ago. The right front tire wobbles along with the steering wheel, it does this at any speed. I noticed the Pitman arm in the right side can be moved by hand and has a lot of play, the left side I am unable to move by hand. Should I replace the pitman arm for the repair or is my problem the tie rod?
The tierod can be assessed for wear by physically moving it with your hands (easiest with the front wheel in the air. Any movement is wear, but a few thousandths is no big deal. The gear box is likely your issue. Jim
You might want to post this on the forum just under this one. It's for the N series tractors. Lot's of knowledgeable folks hang out there.
A '51 would indicate you have the late steering box, a better unit than the early one but still both a PITA to work on. Front end wobble can be caused by a few things. Get out your Essential Manuals and get your spindles, bearings, and bushings replaced then get a new kingpin. You can try to adjust front-end Toe-In too. Pulling a steering box is a big job and one reason why owners didn't muck with them much and thus why now so many fail.
FORD 8N TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
Tim Daley(MI)
