Ford 8N tractor
You will be asked to provide more info - front/side mount, voltage and so on then the gurus will provide their sage advice!
lee
The most common reason for no spark is that the points are not working as they should be.
That said lack of info does not help us help you. The 8N came out with both front and side mount distributor and working on them is different like the front mount you set the points at 0.015 and the side mount you set them at 0.025.
Yep, as everyone is saying, you're going to need to tell us if it's a front or side distributor & 6v or 12v if you want some advice. Troubleshooting is different depending on what you have.
75 Tips
The 8N Ford tractor is a 12 volt. It has a front mount dis. and they said that they had the points cleaned and set, but did not say to what.
Well if done right and the points are as they should be and if you had a good shop do it they should be. Make sure you have voltage to the top of the coil if no voltage no spark. Did you install the distributor your self or that shop?? Did you maybe forget the rotor
As old just said, before you check anything else, make sure you have the correct voltage at the top of the coil. It should be battery voltage w/ the points open & about half that w/ the points closed.
Next, make sure your battery is fully charged.
Don't guess; put it on a charger.
You need a strong battery to:
1. Close the solenoid
2. Spin the starter
3. Engage the bendix
4. Provide voltage to the coil.
As the battery gets weaker, the first thing to fail is your spark. If the battery is almost totally dead, all you will hear is the solenoid clicking.
The more current you use to spin the starter, the less you have for the ignition.
Assuming that the bushings & advance weights are ok, & that you have correct voltage to the coil, the most common electrical failure (no spark, weak spark) points on the frontmount are:
The insulator under the brass concave head screw & where the copper strip attaches. (it’s fiber & will wear out; poke & prod w/ your meter leads to make sure it still works)
The pigtail at the bottom of the coil not making contact w/ the concave head brass screw inside the distributor. (With the coil on, the pigtail must firmly contact the brass screw. No contact = no spark.
The copper strip is broken or grounded to the plate. (look very carefully for cracks & breaks)
The condenser wire grounding to the plate or side of the distributor.
The tab on the bottom of the coil not making contact w/ the brass button on the cap. (With the cap on, the tab must firmly contact the brass button. No contact = no spark.)
Incorrect positioning of the spring clip on the plate causing the pigtail to ground. (the open part of the clip goes between 7 & 9 o’clock on the plate. That puts the straight part of the clip opposite of the timing screw at 3 o’clock)
Incorrect seating of the coil on the distributor due to a loose bail or no gasket.(the coil must not move at all; if it does, replace the gasket or bail. Or stick some cardboard under the bail).
Water/moisture inside the cap due to gasket failure or the absence of a gasket. (the cap AND coil have gaskets)
Dirty/corroded/burned/incorrectly gapped or misaligned points. (gap is .015)
Burned rotor, cracked/carbon tracked cap.
Unless the coil is cracked or shows a dead short, chances are it's fine; square coils rarely fail cold. Pull the distributor & do a continuity check.
First, make sure your meter/light works (don't ask....)
You can change points everyday & it will not fix bad bushings. If you are having trouble w/ points failure, check the shaft. If you detect movement, chances are it needs new bushings.
Inspect the points; if they are pitted or burned, replace them. Next, dress the points by running a piece of card stock or brown paper bag through them. New points sometimes have an anti-corrosive dielectric coating on them & old points can corrode or pick up grease from a dirty feeler gauge or excessive cam lubricant. Make sure the points align correctly. Proper alignment is also critical to longevity. Look at the points when they are closed; both sides should mate evenly. Then, check the gap at .015 on the high point of all 4 cam lobes.
Now, follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
At this point, I just put the distributor, coil & cap all back on the tractor as a unit. The reason I do this is because it is real easy to get the cap or coil mis-aligned trying to put it back together one piece at a time & the result is something gets broken or you get a ‘no spark’ problem.
It's possible to put it back on wrong & break it. Look at the slot on the end of the cam shaft. What ever angle it happens to be, turn the distributor tang to match it. Make sure you can tell the wide side from the narrow side on both the cam & distributor! (close counts) Then place the distributor on the front of the engine, gently push it in place & slowly turn the distributor body until you feel the tang slip into the slot. Rotate the distributor body until the bolt holes line up. Then, hand tighten the two bolts until the distributor body is flush w/ the timing gear cover.
Finally, double check your firing order & plug wires. It’s 1-2-4-3, counterclockwise. It’s very easy to cross 3 & 4.
Post back w/ results & any other questions.
75 Tips
How do you check the line up of the number one cylinder with the number one firing order? I have been trying everything, have spark to the top of the coil and then nothing.
The front mount only goes in one way so no need to worry about that. You do need a manual (you did order a manual, didn't you?) to set the advance on it or someone will come along here with some pictures of how to do it. Cylinders are numbers 1- 4 front to back, firing order is 1-2-4-3, so make sure the wires are in the distributor correctly. You want to check for battery voltage, not spark, at the wire going into the top of the coil that sits on the distributor.
Do you recall the famous line spoken by the warden in the movie Cool Hand Luke?
"What we have here is failure to communicate."
The problem is inside the distributor. As W_B & I both said, do NOT worry about " the line up of the number one cylinder with the number one firing order".
Re-read all of that info I sent you. That will tell you (again) why that is not an issue.
And it will also tell you how to find the problem.
75 Tips
One thing I can tell you Bruce knows his stuff. I had a similar problem with my 1939 9N and had replaced just about every component on the Tractor. Bruce told me to stop throwing parts at it and fix the problem. He provided the info that he provide you. It worked and I found my problem in the distributor. So strongly suggest you try Bruce's diagnostic process and I am sure you will be running in no time. Mine is purring like a kitten and stronger than ever...
(quoted from post at 09:34:23 10/24/13) One thing I can tell you Bruce knows his stuff. I had a similar problem with my 1939 9N and had replaced just about every component on the Tractor. Bruce told me to stop throwing parts at it and fix the problem. He provided the info that he provide you. It worked and I found my problem in the distributor. So strongly suggest you try Bruce's diagnostic process and I am sure you will be running in no time. Mine is purring like a kitten and stronger than ever...
You're welcome. Glad to help.
Thank you. I have to relay these messages to another person and I think I finally got through to them. If he has not ordered the manual, I will order one for him.
