Ford 8N Tranny
Shane007
Got my gears replaced, bearings replaced with races and put it all back together with new clutch. Works great except....no 4th gear
whatsoever. Any thoughts?
I didn't have a shift rail set screw properly in its hole.
Does Ace or Home Depot have the detent (roller) balls?
All the balls used on a N tractor are 3/8" It should be a common hardware item BUT the first time I needed one no one local stocked them : (
Thru the years I have busted up 100's of roller bearings for the balls 3/8" is not a common size so my stash was worthless : (
I brought a set of these this set has the governor balls : )
http://nz.sparex.com/carbon-steel-ball-bearing-oslash-3-16-7-8-apos-apos-10908.html
I spec you can find them on the net are a CNH dealer.... You can get them cheap on amazon are ebay, I like amazon prime : )
(quoted from post at 06:13:41 08/24/19) I didn't have a shift rail set screw properly in its hole.
3/8" balls are the same size as used in the throttle rod. They are standard slingshot ammo available in any sporting goods store.
