timjcatt
- Location
- Duluth, MN
Greetings! I was gifted a 1952 Ford 8N that hasn’t run for 12+ years, my first tractor. It has a 12V conversion, side mount distributor. I’m going through all the mechanical checks, fluid changes, etc., but have some questions on the wiring. It looks there was a bit of corrosion from the old battery terminal that spilled over onto the wiring. I’ve already bought new battery cables. Harness appears intact but is now rock solid, no flex. It’s a Delco-Remy alternator with a two wire plug but one wire has been pulled off, I assume this okay as I have read out about “one wire” alternators and the tractor was running fine when parked. There is a green wire that comes out of the harness up closer to the dash that I have no idea where that goes.
My questions are, do you guys think it makes sense just to replace the wiring harness rather than removing and cleaning up all connections? There is a voltage regulator (I assume the original from the 6V system) mounted on the back side of the dash behind the proofmeter that still has wires going to it, would that still be in use with the 12V system? The ammeter reads about +12-ish when engine is not even running, does it make sense to replace that? Any other thoughts on wiring in this situation?
Many thanks, this Forum and the archives have been super helpful!
