I have located a 8n that I can buy cheap.
The main problem with the tractor is water
gets into the radiator. Has anyone seen this problem, and what will I have to do to fix it?
Thanks, Richard.
Water gets into the radiator which in the first place has water in it?? Of course it also has anti freeze. But then abut the only way that could happen is a hole up top on the rad. and that could be a very easy fix or a new rad. which is about $175
(quoted from post at 12:20:01 01/04/10) I have located a 8n that I can buy cheap.
Thanks, Richard.
f you don't want water in it, drain it & put a lid on it. :?:
That is what I get for not reading what I wrote.I ment to say it was getting oil in the raditor. Over look the mistake, I'm gitting old.
Richard
(quoted from post at 14:52:56 01/04/10) That is what I get for not reading what I wrote.I ment to say it was getting oil in the raditor. Over look the mistake, I'm gitting old.
Richard
t isn't uncommon to see a little oil sheen in the radiator. Question becomes how much oil? And more importantly, is there water/anti-freeze in the engine oil?
