My ford 8n was running great then just quit. I have repaired the distributer several times so I bought a new one. I am getting some spark at the points but it is hit and miss I took the distrubuter to a mechanic and had the timing set. Plugs and wires are good. The tractor does have a 12 volt converstion if that makes a difference. Any ideas on what I should try next?
"The tractor does have a 12 volt converstion if that makes a difference."
Yes, it makes a big difference; that's why we always ask: 6v or 12v, front or side distributor. Chances are pretty good that if you have a 12v conversion w/ incorrect resistance in the circuit, you have damaged the coil. So, the first question is for you to tell us what resistors you have.
I'll assume if you took the distributor to a mechanic to set the timing that it is a frontmount. Is that correct? It's a bit cumbersome to set the timing, but by no means difficult. It's in the I&T FO4 manual.
Assuming that the bushings & advance weights are ok, & that you have correct voltage to the coil, (and you haven't damaged the coil) the most common electrical failure (no spark, weak spark) points on the frontmount are:
1. The insulator under the brass concave head screw.
2. The insulator at the end of the points where the copper strip attaches.
3. The copper strip is broken or grounded to the plate.
4. The condenser wire grounding.
5. The pigtail/tab not making contact.
6. Incorrect positioning of the spring clip on the plate causing the pigtail to ground.
7. Incorrect seating of the coil on the distributor due to a loose bail or no gasket; the coil must not move at all.
8. Water/moisture inside the cap due to gasket failure or the absence of a gasket.
9. Dirty/corroded/incorrectly gapped points
10. Burned rotor, cracked/carbon tracked cap.
Pull the distributor & do a continuity check.
First, make sure your meter/light works (don't ask....)
Next, dress the points by running a piece of card stock or brown paper bag through them. New points sometimes have an anti-corrosive dielectric coating on them & old points can corrode or pick up grease from a dirty feeler gauge or excessive cam lubricant. Then, check the gap at .015 on all 4 lobes.
Now, follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
At this point, I just put the distributor, coil & cap all back on the tractor as a unit (it’s easier to do this from the left side). The reason I do this is because it is real easy to get the cap or coil mis-aligned trying to put it back together one piece at a time & the result is something gets broken or you get a ‘no spark’ problem.
Post back w/ results & any other questions.
50 Tips
Trent......what is the voltage at the modern 12v squarecan coil??? With the points open, battery volts. Its the LAW, Kirchhoff's Law.
As for volts when points are closed, I like to see 9.5-11.5v. How to tell when points are closed? Iff'n it ain't battery volts, the points are closed. Iff'n its battery volts, roll yer tractor in gear using them big ag-bar levers called tires while watching yer volt meter. Simple, eh? ......Dell, yer self-appointed sparkie-meister
