The old Ford is getting tired.
It's a 960 or 961, looks like a 4000,
red paint under the blue, might have
been a selectoshift once, 5 speed now.
Compression 125 to 130. Bit of a bottom end noise.
Carb problems this summer; I removed it
and cleaned it, worked ok for a day or so.
Lately it hasn't wanted to start.
I put new carb, new plugs, wires, coil,
cap, rotor, points, condenser. Kept "throwing
parts at it"; was getting desperate.
Still doesn't want to start. I did get it
going yesterday; and set the timing with a timing
light, and noted that the centrifugal advance works. When it does start; it works pretty good,
it does idle a little irregularly, but it
will idle right down to 475 rpm, seems to have
good power. It is running on all cylinders, pull off each plug wire one by one and you can hear
the miss. But it won't start, cold or hot. Shut it off, and it won't start. It won't even fire.
Sometimes, if I put my hand over the carb to choke
it until it tries to fire, then keep cranking it over, it will eventually catch. Sounds like it's flooded, and will sometimes eventually start. That's the only way it will start. I've tried to check for an intake leak, with a propane cylinder
at the carb and intake manifold connections; but
no difference, doesn't seem to be a leak. I've tried advancing the timing, still no luck. The plugs do get sooty; they have for years, I use a hotter plug, and just clean them every few hours of use. If it had a timing chain I'd check to see if it had jumped a few teeth; but I don't think it has a chain, gears I think? I've tried ether
"Kleen Start", no luck; I even pulled out a couple
of spark plugs and sprayed a little ether directly
into the cylinder, still no luck. There is lots of
battery power, it does crank over quickly.
Any and all suggestions greatly appreciated;
I'm about ready to give up.
Thanks.
Thanks.
