Ford 961 value?
JBJake
I have a Ford 631 and might be moving to a larger farm where I'll need a bit more tractor. Probably hay work, maybe light plowing, etc.
I found a 961 workmaster that appears to be in pretty good shape locally and the guy wants $2,850. Below is what he says he has done to it. Do you think it is a good deal? Sounds pretty good to me. Haven't seen it in person but the photos look good.
Thanks.
________________
1959 Powermaster, 5 speed, live power, wide front. Replaced the brakes; vatted, boiled, and rodded the radiator; replaced the right lift arm; rebuilt the exhaust system; rebuilt the carb; installed new fuel lines. I used the tractor on my 80 acre farm baling hay, feeding my cows, and some tillage/seeding. I just finished turning, discing and seeding six acres of oats. The tractor ran fine but needs some minor repairs. I have put it in the shop now, replacing the alternator, rebuilding the steering pump, repairing the lights and replacing a couple of gauges.
A 961 is a nice tractor, JB, particularily a -5 (wide front) version. Lots of power (nearly 50 HP) for its size and user friendly. The vertical gate transmission takes a bit of getting used to but you will probably like it once you do.
The price sounds right if he has done the work that he says he has, even better if he finishes the list.
Check the rear rims for CaCl damage. If it still has the OEM power adjust rims, replacements are not available anywhere and good used ones are hard to find and expensive. If you must change to the common 6 loop style you will need to change wheel centers.
Check that the clutch operates properly. The double clutch is expensive to replace.
Note: PS pumps are a known maintenance item. I do not believe that rebuild parts are available so ask the owner what he means.
I have one in my collection and like it.
Dean
