Ford 971 Diesel
Douke
My 971 Ford Diesel 172 cubic inch is transferring crank case engine oil to my fuel tank. The engine has 43 hours on it since rebuild. This problem has just started at 41 hours. Is the injection pump the only way that way the oil could be getting in the fuel tank?
I don't know how engine oil could be transferred to the fuel tank on a 172 diesel. Maybe I'm just not looking at it correctly, anyway why do you think you are getting oil in the diesel? What's the symptoms?
(The normal complaint is diesel getting into the oil by the way)
jb
There are 2 umbrella seals on the pump drive shaft- one to keep diesel out of the crankcase and one to keep oil out of the pump. I suppose if that seal is bad crankcase oil could get in the pump and then into the fuel tank via the excess/return fuel line.
I wouldn't think there would be enough engine oil in the diesel fuel for you to even notice it but if you know it's there I'd check the umbrella seals.
I agree with the others.
Every place that oil and fuel cross the fuel is under pressure and the oil is not so it would be almost imposiable for engine oil to get into the fuel tank.
Even if oil were to get passed the seals on the bottom of the pump it would be such a small amount in 2 hrs of running time that there is no way you could notice it in the fuel without expensive lab testing.
So we have to ask...... WHY do you think oil is in the fuel tank??????
