Ford 9N Electronic Ignition
I converted my Ford 9N from Points to Electronic Ignition and
I'm not getting spark. I wired it exactly per the instructions. I get
12 volts to the coil. I checked the coil for OHM's and I got a
reading of 2.5 OHM's. This tractor has a 12 volt conversion kit
installed. I would appreciate any suggestion.
I assume since your tractor has been converted to 12 volts that it used to be 6 volt positive ground and is now 12 volt negative ground. Make sure the small (primary)wires on the coil have been switched to correct polarity when converting from 6v to 12v. The electronic conversions are very polarity sensitive.
If your igniton coil is still 6 volt and using a resistor now to step down the 12 volts to 6 volts make sure the new ign module is hooked to the 12v end of the resistor and not the 6v end. Your module is most likely hooked up at the coil and if this is the case then hook the module's hot wire up to the 12v side of the resistor so there is 12v feeding the module and not 6v.
An 9N is a front mount dist, All front mount kits I have found are 6V,If you put 12v to one of them it proply burnt it up. Dean
ok i changed mine and hade the same trouble you are haveing under the dash you have a resistor jump it out and see if you get spark you should now the post on your coil where you would have hooked your ignition wire to gets hooked to groung right to keep your electronic ign from burning up install a resister you want around 1 OHMS up to a 2.50 OHMS i used a 1.8 OHMS the 1 being the hotest fire and 2.5 being about what you have with points
