AZ Rancher
I have a Ford 9N. Told at purchase it was a 1939 but probably a 1941 since keyed switch is on left side of steering column. Tractor has been sitting a couple of years but previously ran. Can't get it started now. Intermittantly my amp meter does not show a negative deflection when the key is turned on. Does this imply the key switch is bad? Also my push button starter switch has to be pushed down real hard and only sometimes turns over the engine, only if I see a negative deflection on the amp meter. I'm afraid my safety interlock cradle may be busted. If so, how do I fix it? Probably not going to be easy. I am getting a good spark at the plugs but engine does not fire. Fuel is getting to the carb. I don't know when the carb was last cleaned.
