kriskaudio
I have a 9n. Strangest thing happened the other day. I used the tractor, then I went inside the house for several hours. I went back outside and the tractor had somehow moved by itself about 20 feet and dug itself into the side of my hill on my property. Loader and scraper were both down so it was stopped by gravity, thank goodness. I looked out the window and saw the tractor in this strange state, so I ran out to move it back where I parked it. The battery was completely drained. No one was around and I was home all day, so I know no one else could have moved it. Plus there was no where to go forward (trees and and hill in the way.)
I've been having some trouble with an intermittent starter switch problem. I push the button (button is down near the base of the gear shift) and nothing happens. Then I will wiggle it, maybe press from a slightly different angle and it will start to turn over like normal.
Well, before it moved by itself, I was able to start it and use the tractor for a while to do some light grading. Then parked it and shut it off. When I turned the key off the volt meter on the dash showed zero, as it should. I remember turning the switch back to the start position and I noticed it was reading -20 for some reason (usually it reads -6 as it is a 6v battery and system.) I thought it was an odd reading, but I just shut it off and removed the key per usual. Then the odd movement thing happened.
Anyone ever heard of this? I am dumbfounded.
Thoughts?
Thoughts?
