ford attachment hydraulics maintenance
1658Dutch
I bought a Ford industrial tractor with loader and backhoe. I was told I should change the hydraulic filter and fluid. I cannot find a manual on the process. Other than changing the filter, do I just drain and refill the reservoir or is there a process of draining and flushing?
(quoted from post at 22:10:18 01/11/21) I bought a Ford industrial tractor with loader and backhoe. I was told I should change the hydraulic filter and fluid. I cannot find a manual on the process. Other than changing the filter, do I just drain and refill the reservoir or is there a process of draining and flushing?
Pretty much just drain and refill, I doubt a manual has much for a process beyond that.
What exact model tractor, loader and backhoe are they? The filter for the loader and backhoe hydraulics was located in different places on different models, or do you already know where the filter is located?
can you send pics of your hydraulic valve bank showin all hose hookups?
im re sealing all valves and new hoses and have a quandry
thx
(quoted from post at 00:49:49 01/14/21) 1958 Ford 1841-S Industrial tractor with a 712; 19-131 loader and 723; 19-300 backhoe
can u send pics of your hydr valve bank??
I have a 723 also and need a reference
thx
(quoted from post at 12:22:42 01/27/21) Yes. Working on getting permission from admin to upload photos.
You show 5 posts on record now, so you should be able to get past the spam filters. Go down to the Test Forum, located at the bottom of the index page, and try making posts there adding pictures, It should work after one or two tries; then make your posts here with the pictures. If you try to post more than 7.5mb total of pictures (be it one picture or 5) it won't accept the post. Some pictures, often from phones, need the size reduced before they will be accepted in a post.
Does anyone have a 755 swing cylinder image of seals and
packing. I attempted to have Openloop do some cylinder
repair and estimate came out to $1700 for a complete rebuild.
Not the money I wanted to spend. So I preferred preserving
and packing myself. However they took it apart and now I’m
playing a guessing game on how they go on the rod. The
manual I have shows the rod but it’s black and white and no
instructions on how it should go. After watching many cylinder
repacking videos I have come to be wary of the way and
direction seals are placed. I attached the only image I have to
reassemble the cylinder back. Is anyone able to assist me
with a description or image? Anything helps
Sending four pictures of 723 model; most likely close to 755. However, the pictures are for the "Old Style." I noticed your picture shows, "Old Style," so I am assuming that the larger depiction is a modified newer updated style. Most likely being the seal kit that you purchased being the updated style.
