Ford Auto Hubs
4430jd
My 2007 F-350 auto locking hubs have quit working ,It says it is in but do not lock in, If you turn hubs to lock 4x4 works, Any Ideas?
I checked 30 amp fuse for shift on the fly it was good.
The hubs are vacuum controlled, if there is a vacuum leak because of a bad O ring in the hub or a bad vacuum line the hubs will not work in the auto position.
Vacuum hubs? Never heard of that. I know some vehicles have a vacuum or electric divider on the front axle, but that is for vehicles that do not have locking hubs.
I hope to learn something here.
Yes,vacuum operated.Very stupid design in my opinion as they give lots of trouble here in the "salt belt".
You can check the operation of the hubs with a hand held vacuum pump and see if they engage.There is a vacuum fitting at each hub.
Most guys Ive known start having trouble with auto-locking hubs just switch to manuals.Cant imagine what that cost for todays newer trucks,but I know alot of guys have did it over the years.
Good Luck
Stan
If your truck is out of warranty, and you decide to change the hubs, take it from me...as an ex-Ford parts guy, you can buy a PAIR of Warn hubs for around the price Ford gets for a SINGLE. On out-of-warranty stuff, we did a TON of business with Louisville Four Wheel Drive, and saved our customers a TON of money.
