fORD BACKHOE LOADER TRACTOR
macbeth
Can anyone help me identify this old backhoe, or tell me how. Serial under hood is C380794. Numbers on left side of flywheel housing are 3D20C and AD70B03
3D20C is a date code for April 20, 1973 afternoon shift. C380794 is a 1st half 1973 serial number, made in USA. AD70B03 doesn't compute as a model number, model number should be 6 characters. Maybe post some pictures of the tractor, numbers, look closer at codes etc. I think the model number should also be shown under the hood.
Model number is under hood but I cannot read it. It is a 3 speed with high/low and no shuttle. Looks like a 3400, but I dont know. Diesel engine is stuck, man wants $2000. Doubt I could give that much.
3400 is a pretty good guess, matches other info O.K., I would go with that.
Stuck diesel engines are neither easy nor cheap to fix. Even if you can find a donor engine you'd have tons and tons of dead weight to pull off the tractor to get down to the engine to replace it. I recommend a hard pass on this one unless you've got the facilities.
I can do it. Just cannot see why I would work hard to lose money. Although it does seem to happen pretty often.
