Harold Hubbard
I plow snow for several residential properties. In the distant past, when heavy equipment was not as universally available, I used my JD 1010 dozer as a backup and push back machine. That is off the table now, except in absolute disaster conditions. Nobody wants to pay for that machine crawling around at two miles an hour when there are faster more powerful alternatives available.
So several years back, I started renting machines from a local excavation company. That worked well, until they started requireing insurance coverage that I couldn’t afford, for the short time I would use them. So I used their machines and operators for a few years. At this point I can just barely break even on that, and I want to buy my own backhoe. I need 4x4, cab and heat.
Ford x55 models seem to run cheaper than comparable Cat, JD, or Case. But, three out of the five ads I have seen, mention transmission issues. So, is this common, or am I just seeing owners trying to unload something before it gets worse. I understand these are all 25-40 year old machines, but so are there other brands I have looked at. Almost none of those mention transmission problems. They are more likely to be bad engines, rotten tires, leaks, broken glass, and general wear.
