Ford Dearborn 14-16 Scikle bar mower
slk
When using a ford dearborn 14-16 sicklebar mowers do they have to rest on the ground, or can you raise the 3 point hitch and cut about a foot of the ground with the sickle bar suspended????
Steve
My experience is that you can cut with the mower raised 1 foot suspended, which is the same as raising the mower at the end of a turn around, without desingaging the Pto.
Having the balance spring adjusted to a proper level bar is necessary or minor adjusment can be made with the leveling crank on the 3 point.
Charles Krammin SW MI
