Ford Diesel 2000
tiptonwebb78
I have a Ford 2000 and when I start to go up a hill it dies. The problem has been ongoing. Yesterday, I put on new gas tank and a new fuel injection pump. Now when it idles and I must keep the fuel at least half instead of slow idle or it will die I can drive it but when I start up a hill it still dies. Any ideas?
Most likely you fuel delivery is restricted. remove the line at the inlet to the injector pump
(IP).make sure your tank valve is fully opened and be prepared to catch the flow in a container.
You should have a continuous gush of fuel coming out the end. Do you have a lift pump? If you
do it is generally a mechanical pump. If you have a lift pump crank the you should see a
continuous gush of fuel. If it is intermittent or dribbles, you have restricted fuel delivery.
Work your way back to the tank to find the cause. It could be a pinched fuel line, debris in the
filter head, the fuel filter, or a fitting, debris in the tank out let or fuel valve. If you do
have the prerequisite continuous gush of fuel, there may be a screen in the IP inlet that has
debris in it.
Make sure your air cleaner and intake manifold isn't plugged since it takes both fuel and air to
make powewr.
If it has NAPA/WIX fuel filters, MAKE SURE there's NO O ring in the filter top outer groove, that's the fuel inlet passage and MUST NOT be blocked. Lots of service calls
have been made to correct that mistake.
Like Jerry posted, before you trash that poor pump make sure that it has fuel coming to it. What Jerry left out is that gush of fuel has to last for awhile. Long enough to run a pint in two minutes. Maybe you have already done all this, but you are leaving us in the dark so we have to find out one thing at a time.
(quoted from post at 12:30:33 03/06/22) Have you replaced the fuel filter? That
should've been first. Is it frozen where
you are? Might be ice blocking fuel flow.
Hi thank you! Yes I have replaced the fuel filter and Im in TN good weather
Thank you. I needed to get my old pump rebuilt, and a new one was $100 difference. I am going to keep the old pump, but I have not checked to see if I have restricted air flow
USUALLY that symptom, on a 3 cyl diesel 2000 would mean a slug of water in the fuel tank that moves when you go up hill or a slug of moss/algie crud in the tank. But you say its a new tank.... And you say it starts fine, runs fine and pulls okay on level ground... or at least you did NOT say otherwise. If 4 cyl 2000 then there is the linkage that cuts off fuel that could move, but I guess the cutoff linkage on a 3 cyl could move back as well if the cut off cable were loose, bad, or mis-adjusted.
THen on the 3 cyl , there is the gov/cage/weights that could have come loose inside the pump causing this, but the tractor would have a lot of other symptoms on level ground as well that you dont describe.
Take the fuel line that connects to the rear of the pump loose from the filter or pump, whichever is easiest, open the tank valve and check for a good fuel flow, if the flow is weak or dribbles you have blockage somewhere.
That's always the first thing to check before swapping parts.
(quoted from post at 14:58:15 03/07/22) USUALLY that symptom, on a 3 cyl diesel 2000 would mean a slug of water in the fuel tank that moves when you go up hill or a slug of moss/algie crud in the tank. But you say its a new tank.... And you say it starts fine, runs fine and pulls okay on level ground... or at least you did NOT say otherwise. If 4 cyl 2000 then there is the linkage that cuts off fuel that could move, but I guess the cutoff linkage on a 3 cyl could move back as well if the cut off cable were loose, bad, or mis-adjusted.
Thank you. It is the 3 cylinder- I did not consider a cut off cable
Thank you. I will check the cutoff linkage
Thank you for the advice- the tractor set for years and the new parts were necessary - not much price difference in the refurbishment or new.
