John B.
I just had a coworker bring in his early 90's Ford F150 four wheel drive into the shop and jack up the front end by putting the jack under the front frame crossmember. This caused the front axle to hang by the suspension and the front drive shaft to extend out at the slip-yolk.
Well when he let it down the slip-yolk didn't slide back in and put all the pressure on the transfere case and thus cracking the case.
I just thought I'd pass this bit of info on to others and hope it will save you some money.
That will make for a bad day allright. It probably says in the manual not to put the jack there. Life is a learning experience. Stan
Must have been something wrong with the slip joint or suspension/shocks.
Otherwise it would have broke anytime the vehicle became slightly airborne bouncing over a bump!
Could be broken suspension, but I'll go out on a limb and say it was modified (lifted). Lift kits are death traps. Most don't include extensions for drive shafts, or more importantly, steering wheel shafts. I knew someone who died when the steering on his lifted CJ7 popped out.
First of all, it's a Ford!
I feel sorry for anyone working on Fords. Ford mechanics have to be the best there is to be able to work on these and make a living. I'll work on Chevy's with a smile but hate Ford's.
Too many goofy things about them. Remember, Ford started by making the cheapest cars possible as quickly as possible. Good luck!
They ALL break ! No matter what brand you have ,,they all have problems that better engineering could have avoided . Dodge front ends,transmissions . chevy injectors, wiring. Ford insane cab removal to work on late model trucks . etc . What ever comes in my shop ,,I find some reason to cuss the one who designed it ! lol
Soemthing was lifted , or changed. In stock form I have never seen this happen .Should"nt matter where you lift it . When I lift with hoist it lifts by the frame , everything hangs . Never saw driveshaft trouble .
