Ford Factory Rims
I'm in the process of replacing some tires. I've found some decent used tires on original ford rims. My tires are on original ford rims as well. I noticed that the tires I'm looking at have the valve stem on the inside of the tire, where my rims the valve stem is on the outside of the tire.
Is one way the correct OEM way?
Why are they different?
Thanks!
Valve stem can be on one or the other - no set correct way. Tire tread has 8 different settings from "48 to 76" and you switched out rims and center discs to get the setting desired so one setting may have valve stem inside, another setting to outside. OEM FORD/KELSEY HAYES 28 x 9 Hat Rims used on all N's with 10 x 28 (now 11.2 x 28) tire size. Looking for a set of OEM Hat Rims? I have two sets. One with the OEM FIRESTONE CHAMPION SPADE GUIDE GRIP closed bar centers included, up for sale. I also have a few sets of OEM FORD/KELSY-HAYES stamped 3 x 19 rims on Firestone 4 x 19 single rib tires for sale. Email is open.
FORD 9 x 28 HAT RIMS; 8N AND UP CENTER DISCS:
TIM DALEY & 1948 8N FORD TRACTOR:
Tim Daley(MI)
(quoted from post at 06:36:10 09/28/20) Valve stem can be on one or the other - no set correct way. Tire tread has 8 different settings from "48 to 76" and you switched out rims and center discs to get the setting desired so one setting may have valve stem inside, another setting to outside. OEM FORD/KELSEY HAYES 28 x 9 Hat Rims used on all N's with 10 x 28 (now 11.2 x 28) tire size. Looking for a set of OEM Hat Rims? I have two sets. One with the OEM FIRESTONE CHAMPION SPADE GUIDE GRIP closed bar centers included, up for sale. I also have a few sets of OEM FORD/KELSY-HAYES stamped 3 x 19 rims on Firestone 4 x 19 single rib tires for sale. Email is open.
Tim Daley(MI)
orning, your email link is not open in Modern or Classic on my Android. I would like to contact you about some 19" wheel weights.
Thank's
Morning, your email link is not open in Modern or Classic on my Android. I would like to contact you about some 19" wheel weights.
Thank's
His e-mail is open on classic! You have to log in on classic to see the Send Email link on the right bottom corner of his post.
(quoted from post at 07:00:52 09/28/20)
Thank's
our right.
