ford hydraulics
abane
I have an 860 Ford tractor and in cold weather it takes forever before it will lift. I had transmission-hydraulic fluid in it and drained it and put in hydraulic fluid and it works about the same, slow.The owners manual calls for 6 quarts of Ford hydraulic fluid and 2 quarts of additive that you can't buy anymore. What do some of you use to make the hydraulics work better?
AB:
Use ONLY CNH 134D or equivalent oil in the hydraulic system in your 860, NEVER GL-1 Trans/hydraulic fluid. FYI, you can use the same oil in the transmission and differential as well.
IF you have the proper oil in the sump and no water, the slow response after startup is most likely due to loss of pump prime or a sticking unloader valve.
Dean
