Ford Indenticfication (340A or B?)
Lorijane
This message is a reply to an archived post by 35 Whelen on August 07, 2011 at 08:13:34.
The original subject was "Ford Indenticfication 340A or B?".
Need help as well determining model
Hydraulic level check and capacity please
Look on the under side of the right hand hood panel, aove the battery, for a foil sticker that has the model number, Tractor Number (serial number) and Unit Number (production date code) and post those numbers back here and we can tell you what it is and when it was made.
If the sticker is no longer there or is illegible, the same numbers are also stamped into the flat spot on the transmission bell housing just above and just rearward from the starter, above the two large bolt holes.
