Mr. T. Minnesota
Forum,
Finally completing installing a used 172 Ford Industrial diesel into a Pettibone log skidder this week. The replacement engine came out of a 900? series tractor. Problem is the cam gear end of crank protrudes farther forward than the original industrial engine. This is a problem because more space is needed to connect the front mounted hydraulic pump which operates the articulating steering on the skidder. Question is what will I find under the different cam cover on the 900 series engine, an extension or solid shaft and what should I do, move the pump forward or ?? Were there different length crankshafts or not, I hope not?
Hope this makes sense! Any and all thoughts are welcome!
Mr. T. Minnesota
Mr. T. Minnesota
