Ford Jubilee carb
Danny Boy
What is best replacement carb available for Ford Jubilee? It currently has Marvel-Schebler.
I want one ready to bolt on and go for summer tractor shows...tired of trying to make the original work.
Danny, the best replacement would be another TSX-428 rebuilt by a good carburetor guy on an exchange bases. Someone may offer one on here. Especially if your taking your Jube to shows, etc.
(quoted from post at 11:49:14 06/26/21) What is best replacement carb available for Ford Jubilee? It currently has Marvel-Schebler.
s Jim said, an original, rebuilt is your "best replacement" Will still need to be adjusted once on your tractor
I don't understand why folks have
problems with the old MS carburetors.
They are about the simplest carburetor
there is. The only thing you have to do
to make them run right is clean every
hole with a tip cleaner or similar
object. Cleaner or air doesn't work.
Why would you want an aftermarket on a show tractor?
I rebuild them, test and adjust them on my tractor, then send
them back ready to bolt on and go for less than a replacement.
Not cheap, but less than an aftermarket replacement in most cases.
My email is open on modern view if you're interested.
