old
- Location
- Camdenton Missouri
So got a call today fro ma guy about his Jubilee not starting. First off found a bad new starter button. But then worked around that and it would not start. Had to adjust the points a bit but yet no start. Hot wired it would run but not run with the key switch. Traced things down to being bad amp gauge. You could grab the gauge from the under side and move the insides of the gauge around and if you moved it just right it would run but soon die due to the vibrations of it running moving the amp gauge. First time I have run into a problem like that.
