I've begun work on my father's Ford Jubilee after his death and I've run into a couple of issues. This would be my first time doing maintenance on an engine of this proportion so forgive me if I make a few errors. Previous to it sitting for a few years it was in perfectly operational condition, but as previously mentioned it sat and acquired a plethora of issues. The most prevalent of which being that when the engine is being started it cranks for an indefinite amount of time and never seems to start. I have gotten it running by shocking the post on the starter and when it does run it does so quite well. It appears that after about 30 seconds of cranking the engine the battery starts to slow down and eventually the turning stops altogether. From what I understand it should start as soon as the button is pressed. I have replaced the solenoid and battery, cleaned all wire contacts, and verified the 12 volt conversion was done properly. I am at a loss as to what is causing this problem, possibly I need to clean out the starter, and if so how? Also, if anyone can tell me what kind of wires an Ultima 01-0039 alternator requires to self excite that would be much appreciated. Thanks in advance.
