wcurley000
My Ford jubilee is occasionally back firing and has little power and stops when only small load. Firing order is 1 2 4 3 and number 1 cyl is connected to the 10 o'clock post on distributor with the 4 cyl on post nearest coil connection all in clockwise order. Good spark at plugs. Cleaned carburator. Full tank of gas. Changed plugs, points and condenser. Suspect a weak condenser. Plan to check compression. Plugs have a lot of black residue after only short time running and exhaust is black when first started but gets better as engine warms. Why no power and hard to start? Also stalls when even under light load.
