Ford loader on a 6610
jledlow
My tractor has the dual hydraulic hookups on the back. I already have dealt with my 6700 with the dual remotes that one set will not operate a loader. I would love to set my loader up on the 6610 without having to tie up and constatntly plug and unplug the loader in order to use the remotes for something else. Can I use the power beyond plate in order to hook the loader up and use the joystick without having to sacrifice my dual hook ups?
I’ve always been told no on that system
You are supposed to tee in the the remotes supply line and return through the fill port
Also requires a closed center loader valve, most older valves can be converted, don’t know about todays new stuff
You need to be more specific about what the tractor has. "Dual hydraulic hookups" doesn't really mean much. Main question is does it have dual pumps? Is there a pump mounted on the left side of the motor with a filter screwed onto it? If yes, then you need to consider the load sensing loader valve option. If no, then a much cheaper and simpler option is available.
It does have the dual pump setup. Yes the pump is on the side of the motor with the filter. I do not know about "Load sensing valve" Not very experienced when it comes to hydraulics or how they work. My experience is "If it works leave it alone and if doesn't find the broken piece and replace it"
