Ford ? Model
Charnerl
I have a friend who ask for info on his ford. I can't find it. Serial No. is 128965 with diamond on each end. It's blue, but that don't mean anything. It has a roll type hood as NAAs and there is no front round emblem. It does have a half moon on the front of the hood roll about the size and shape of a taco. The grill is missing along with other parts. Any help will be apprecated.
It's either a 2000 or a 4000. Built from 62 to early 65.
There should be other numbers where you found the serial #.
Post them and someone will sort out what you have.
that will be an early 000 sweries, 63/64 year model. choices are 2000 / 4000
if the model id on the bellhousing near the sn is gone.. post the CASTING number on the block and we can tell you if it is a 134ci block likely menaing it is a 2000 or a 172ci block, denoting a 4000 ( unless blocks swapped..e tc. )
of course.. there is always the possibility the tin was swapped too.. :)
post back
Ultradog
Got a question, on your 201 flex hitch disc that you reworked and cut down, the scrapers that became extra parts, would you consider selling them or are they backups. Looking for (2) rights and (2)lefts, last resort is to fab them!
Thanks for any info
I just looked them up on Messicks but at $43 apiece you will probably pass huh?
I do have some here. Have to look.
I sent you an email.
201 on Messicks
