Dylan/Noah
Two new 6volt coils failed in less than 1 hour run time. Coils purchased from two different local tractor/implement dealers. Both identically marked with p/n and origin of manufacture. Both indicated to use on system without an external resistor.
Checking for spark always indicates the coil as the problem. New coil results in engine start and normal operation, but only for a short period of time. When the engine operates with the new coil, I can shut off and restart until the coil fails.
If problem is not the coil, why does a new coil initially fix the problem?
