I have a Ford NAA tractor that I recently purchased. The engine was seized. I took the engine apart, got it turning, put new rings in and put it back together. The bearing looked to be fine. I put new oil and new filter on it. I tried to get oil to the top by removing the distributor and turning over the oil pump. I got very little pressure. I decided to get a new oil pump. With the new pump installed, I still get minimal pressure. There are signs of oil in the lifters and a little to the rocker arms but not what's needed. I took the oil filter off and tried pumping to see what came out; again minimal oil flow. What's wrong and what am I missing?
