My father has a 1953 Ford Model NAA/Jubilee Tractor that has a starter switch issue.
My grandfather borrowed the tractor a long time ago and that's when the problem occured. Being a do it yourselfer he was able to still start the tractor by removing the wire from the starter switch on the transmission housing and temporarily touch it off to one side of the starter solenoid (-ve side I think). He operated the tractor like this until we recently took it back and are now trying to figure out why the tractor won't start when that same wire is hooked back up to the starter switch.
The tractor still has the orginal 6V Positively grounded system and runs fine once you get it started (without the starter switch in the loop). This to me seems to suggest that everything in the electrical system is fine except for the starter switch itself. We've disassembled and removed the starter switch from the the transmission housing and tested it with a voltmeter and it seems to work just fine however we still have no joy once everything is all assembled.
I've reviewed some posted wiring schematics for the NAA electrical system and they look straight forward but I still must be missing something.
Can someone offer any advice as to what I might be missing or explanation on how that whole electrical system with the starter switch is supposed to work.
Thx.
Kyle Norris
Canada
Thx.
Kyle Norris
Canada
