Ford NAA question
Hello,
New to the Ford tractor world and my brother in law said there is a plug in the engine to drain the remainder of the antifreeze from the block. Attached is what I found and wanted to confirm it. From the research I did, it is a 1/4" plug which I happen to have.
(quoted from post at 19:06:22 03/16/21) That look to be a broken off temp censer not the drain plug. Drain plug should be a simple pipe plug.
Drain cock, missing the turning ears, opening filled by a mud dauber?
either the ears are broke off or he has a twig jammed in it. that was common. farmers dont have pipe plugs you know, lol.
I did find on a Youtube video showing that there should be a plug there. No telling what happened here. There was a wasp nest on the radiator, this tractor did set outside for 7-10 years. I'll trace out the temp gauge to be sure. Thanks everyone, knew this Ford would be an education (nothing wrong with that).
Temp sensor would be in the head not the block. Oil pressure sensor would be further back. You have it.
