ford naa solenoid
the solenoid went bad on my naa so iwent to napa and bought a new one could match up the old one now we cant use starter button we have to use the button on the solenoid do they make the same one i took off i even changed the starter button thank for any help
That happens frequently. Wrong solenoid.
The tractor ones used ground to actuate, the car ones used power.
They look identical but electrically they aren't the same.
NAPA can get you the right one or you can order it online.
I don't have the part number handy for the NAA solenoid.
The 8N one from NAPA is ECH ST540.
They are the same electrically but the mount is different.
If you have the correct one there is a battery side and a starter side and if you have it on backward it will not correctly. Or you may just flat out have one that looks the same but is no tthe same
