OK8N
Picked up a $100 dirt scoop today for the 8N. The previous owner couldn't figure out the dump release. I got it to release, but the mechanism doesn't seem quite right. Is anyone familiar with this model of scoop? Does the release look correct?
I have that same scoop. It does not have the spring assembly like yours. The PO must have added it to hold the release.
Mine has a cam-type release in the linkage. This pic of mine is a bit far away, but maybe it'll help....
<a href="http://s11.photobucket.com/albums/a167/lonestarjeff/Ford%208N/?action=view&amp;current=dearbornimplements001.jpg" target="_blank">
dearbornimplements001.jpg" border="0" alt="Ford rear scoop
</a>
Disassembled the latch today and found the latch bracket to be slightly askew. After straightening, and a good lube all around, the bucket performed as it should. The spring tension was also a little too strong, making the lever stiff. It works very well now with minimum tension.
