FORD SELECTO SPEED
Allen L
There is a Ford 871 tractor for sale with the select speed transmission. I have heard they had a lot of problems, Any insights as to this transmission would help my decision. I am told that all 10 gears work great on this one but hard to push into park. Thanks in advance for your time of reply. Allen
the 01 sos is where most of the horror stories come from.. that and lack of maintenance. later models had less kinks.
in short.. if you find one thast is well maintained and working.. and perhaps has had a traded out tranny.. and you keep up on maintenance and adjustments.. it should last. if / when it does shell out.. it's a gamble. can be 25 cents or 2500$ to fix. in my neck of the woods, a sos brings about 1/3 to 1/2 the price of a 5spd.. and perhaps not so much but some difference on a 4spd.
run it hot and cold thru all gears and ranges and load the pto. if it passes those tests.. I'd make a fair offer on it. if it has known issues.. consider your offer price with thos in mind.
soundguy
I was some what in the same boat when buying my tractor, but coming up on soon will be a year with the tractor; the S.O.S has become the least of my worries. Pretty much what Soundguy says, just be prepared to walk away.
Marto
I've had my 671 for three years now and it has the original transmission (312259). Everything works fine and the biggest load I put on the machine is snowplowing.
I've changed the fluid and filter and had to replace a broken spring on the inching pedal but otherwise it's been very dependable.
SouNdguy's advice is right on.
Jack
maybe a shift cable adjustment on the park issue. Put the transmission through its paces both cold and at normal operating temps, as has been suggested. If it passes, go for it! The bark on these units is generally much worse than the bite.
I have 4 sos"s and had little to no problems with any of them sound guy has helped me with the few problems I have had I would trust his advise hes been around them longer than most I would suspect
SouNdguy can correct me if I'm wrong, but I don't believe he's had much if any actual experience on Select-O-Speeds. What he shares about them, he's gained from reading what others with the experience have had to say and from reading shop manuals.
I, personally, am not one who would devalue an SOS equipped tractor as much as he and some others do. As a matter of fact, I would rather pay for an SOS tractor than do so for a corresponding 4 or 5 speed.
I also own six of these Select-O-Speed tractors and have been around them since 1960 when grandpa bought a new 871. I was just a kid then, but fell in love with the SOS.
soundguy, if select-o-speeds are worth 1/3 to 1/2 of 5-speeds I have a "58 961 that I"ll trade for a two 971/981"s. Let me know if you find anyone up for this swap, thanks, Kyle
I agree with Larry and Andy. I have a 64 4000 gasoline S-O-S, once had a 66 4000 gasoline S-O-S, and regularly help my friends with advice and maintenance with their S-O-S tractors.
I like them and often recommend them to friends over 4 speeds (always) and live PTO 5 speeds (often) due to the versatility as well as the (usually) lower purchase price.
In my area, when dealing with dealers or others who are tractor knowledgeable but not S-O-S knowledgeable, one can say the right words to the seller and usually get a very good price. This strategy does not work, however, if the seller is well experienced with the S-O-S.
Dean
just telling you the sales prices I've observed.
unfortunately 9xx rowcrops themselves are pretty low priced items no matter what. don't think I've paid over 1500$ for a 9xx yet... ( 7xx are a different story. ) Also.. wide fronts tend to add a lil value as well as goodies like aux trannies. I have seen 4spds with sherman combos hang right with *6* machines in price... even with non live pto..e tc.
soundguy
