ford sickle bar mowers
They are both pitman-less (wobble box?) mowers. The 515 is the older, actual Ford design. Main frame is made of mostly round tube. The 505 is a rebranded IH 1300. Its main frame looks to be made mostly of flat stock steel. If you Google image the two, you’ll see the difference.
Upvote 0
And confuse neither with the Ford 501. Likely most common. Pitman Arm mower. Main frame looks similar to the 515. Ok mower. Cheap.
Upvote 0
thanks steve
Upvote 0
thanks steve
Upvote 0
