Ford tractor model?
CES
Hi, Can someone tell which model i have? Yellow Ford tractor with a 525 loader. I was told it is either a 515 or 535. SN: C503281 6D2 stamped on the bell housing. Sticker under the battery hood is missing. Thanks.
there will be three rows of numbers there, the top will be the model code, with that we can tell you all about it, should start with "DD1 or DD2"
the serial number is for a 1976 model year, and that date code is for April 2, 1976
as a side note those models are the same tractor except the 535 had a loader, so most likely it's a 535, but get that number and we'll break it down.
Hi, thanks for your help. DU112K 6D2 C503281. The U in the first set of numbers is most likely a D per your response, but it looks like a U. Numbers are worn down.
Hi, After thinking about the first set of numbers/letter, I'm sure it's a u. I got a good visual on it while hold my flashlight beam across the face.
Hi Joe, sure it's a U, not a D from my previous response. I was able to run a flashlight beam across the face of the numbers making it very clear to me. Worn, but clear.
