ford tractor
rick troxell
my youngest son purchased what he says is a ford9n. it is a ford. It was used to cut along roads by Pa dept of transportation. It has duel wheels in the back. How do i find what model and year it is on the tractor so i can help him find parts. The engine has a slight miss and the bowl at the carb is leaking. It is also an automatic transmitiom. 10 forward and i belive 3 reverse.
"How do i find what model and year it is on the tractor so i can help him find parts."
You said your youngest son says it is a model 9N.
Look on the left of any YT page and click on Serial Numbers to find out the year.
If it has powershift, it is AT LEAST 12 to 15 years NEWER than the last 9N.
That tranny is the "SOS"... Select-O-Speed, and it was available in a variety of number-series tractor models AFTER the 9N, 2N, 8N, and NAA.
Post on the "FORD" Board, and one of the gurus there can narrow it down more for you.
FORD
Hey there rick;
Can't say i'm an expert on fords "N"series
of tractors.BUT I can say i've never heard
of an "automatic" transmission on any of em.
Bob
God Bless
Either someone has too much free time and a junkyard or its not a 9N. The 9N has 3 foward and 1 reverse speed.
You posted "The 9N has 3 foward and 1 reverse speed."
That IS true, UNLESS it has one of several aftermarket auxillary transmissions, Lanse, which are reasonably come on the old "N's", at least in some areas of the country.
But the "automatic" (powershift) thing DOES rule out the older tractors.
Sherman and other Auxillary transmissions
thanks folks. I will apparently have alot to learn and so will the boy. will post in the ford forum after i get more info off the piece of equipment
On the right hand side where the transmission case and the engine come together there is usually a flat spot where serial numbers and possibly model numbers are stamped. If they are still visible, they should help you ID this machine.
is there any way you can post a pic of the tractor? someone here will be able to id it if we can see it, then this site probably has parts for it
