ford workmaster clutch
WWQ
I haven,t uesed the ford for about four mounth I started it up today and it wouldn't go into gear. It's like the clutch went out just setting there. It was getting weak but it still worked. What is it going to cost to get it fixed and is it going to be worth it or should I try to find another tractor. I have a 90 horse tractor to feed with but I can't work my garden with it or brushhog.
Thanks WWQ
Your clutch has rusted/frozen/stuck.
Do a search here for "stuck clutch" for advice on unsticking it.
Like Bob says the clutch has rusted tight to the flywheel. Many thing you can do if you want t do it. Block the clutch pedal down for one and leave it that way when ever you park it. If it is out in the open start it in gear and take it for a drive holding the clutch pedal down and just go till it pops free but do that only if it is safe to do so and be sure nothing is in the way because the only way you can stop till it frees up is to turn it off
