Fordson Dexta Diesel
aklimek100
This message is a reply to an archived post by ROADMAN on May 18, 2011 at 06:08:25.
The original subject was "Re: Fordson Dexta Diesel".
in 2011 you had a super dexta i'm looking for a block and crankshaft if you still have it or know where it is
thanks
my ph # 315 404 6324
thanks
Tony
(quoted from post at 08:40:36 02/27/19) I have a complete Dexta engine for rebuild
CTOR PUMP
IS IT A 144 OR 152 ? IF YOU HAVE THE INJECTOR PUMP. YOU CAN TELL THE CU. IN BY IT SHOULD HAVE SIMMS PUMP IF THE SER# IS P4588 ITS 144 IF ITS P4696 IT A 152.HOW MUCH DO YOU WANT FOR THE MOTOR?? I'M IN FLORIDA BUT WILL BE GOING THRU VIRGINIA THE FIRST WEEK OF APRIL.
ADVISE OR CALL 315 404-6324
THANKS
TONY
It is the super with mechanical pump.
Engine is not frozen. $500, with.
Flywheel, Clutch and bolt on items.
I used the complete rear end of the tractor
when I had to replace a transmission on one
of my Dexta tractors.
WAYNE
(quoted from post at 19:40:51 03/17/19) It is the super with mechanical pump.
WAYNE
Wayne
is it a super dexta or just a super. i don't think a super will work for my application. it is a three cly perkins diesel correct. any way to post a picture? you are located in Virginia? please advise as soon as possible as i'm headinh north soon.
My farm is 1.5 hours drive one way. Not going there until this weekend.
It is a super, 152 3 cylinder Perkins type engine. It has the Minnmec pump. The tractor has super nose cone and tin.
Like I said, I used the rear end, because after 1961.5, all the tranny's use a larger output shaft and bigger connecting shaft. I married engine tranny back together without a connecting shaft between tranny and rear end (old early Dexta rear end)
I will have to pull the engine. This is a parts tractor.
Wayne
8047040091
