FORDSON SUPER DEXTA
MIKEB6503
I"M WANTING TO KNOW IF THIS SERIAL NUMBER IS FOR A FORDSON SUPER DEXTA #09B729117 AND IF IT IS A 1962? I JUST BOUGHT IT A COUPLE OF WEEKS AGO.
THANKS
MIKE
Hi Mike,
Brian's right, it would be a '62 model.
But, Dexta's and Super Dexta's used the same serial number sequence.
However, they used different engine serial numbers. (Stamped into the block on the upper left hand side)
If it starts 16..... it should be a Super Dexta.
If it starts 14..... or 15..... it should be a Dexta.
But, it could also have had the engine replaced at sometime!
Are there any decals on the sides of the hood or the top of the nose cone?
I would guess it to be a late Nov or early Dec/62 as the last 09B was about 09B731469 made the end of Dec/62 and most likey a Super Dexta as there seem to be fewer Dextas manufactured later on in '62. (atleast recorded in tractor registries)
Les
LES,
I WILL CHECK THAT ENGINE SERIAL NUMBER WHEN I GET HOME FROM WORK AND THANKS FOR YOUR HELP. BY THE WAY THERE ARE NO DECALS ON THE TRACTOR ANYWHERE.
