Fordson super major cooling system
Stevie C
Location
Uk
Hi i am in the process of restoring a
fordson super major. Starting at the front
as the water pump is leaking.. ordered a
new one with hoses etc..while it's all to
pieces i thought it a good idea to replace
the thermostat as the tractor hasn't
started for years.. but on viewing a few
new ones some seem better quality than
others..my problem is really the confusion
of the correct degrees as some are 72 74
82
What is the best or correct one?
Over winter into spring my plan is to move
around the tractor fixing and giving it a
good service/repair
82C thermostat and 4 lb radiator cap. If you have a later model Super Major with the Mininmec injection pump make sure you change the oil in the injection pump.
Thank you for the correct answer and yes
it does have the minimec injector pump i
believe the oil to be sae30. I will
definitely do that too..
