Fouling Spark Plugs?
OLTWOPOP
I have my late father inlaws 1947 B JD that he was fouling plugs on it all the time new plugs would foul faster than putting in old used ones.
He was lucky to get 5 hrs run time before fouling a plug. After he pasted I had the same problem with it. I checked the valve clearance, reset the carb. reset the points. It had a real good blue fire spark that would jump 3/4". But would still foul the plugs. You could pull the plug wire off at the plug and let it jump to the plug and it would pick back up the dead plug. I remembered seeing spark jumpers on old tractors in the past to keep from fouling plugs. But I didn't want open spark on it, Too dangerous. So I ground about 1/8" off the contact on the rotor bug letting it jump more inside the cap. That was 6 years ago I have not fouled a plug since. It is 6 volt with a dist.
Has any body else had a problem fouling plugs? Is it due to the gas not being leaded any more? or what? My Opinion is not very high of the spark plugs sold these days for old tractors. We had tried all brands and heat ranges before grinding the bug.
Any and all spark plugs will foul when the mixture is too rich and the engine too cold or if it"s an oil burner.
Get the coolant temp up to 195+F, lean the carb idle & main back and see what happens.
If it still fouls plugs drain the oil and use some CF-2 low ash 40wt oil rated for two stroke detroit diesels. CF-2 burns with less ash deposites left behind.
If the plugs are Champions, practice your best throwing arm towards the garbage pail. Install Autolite 3116, Denso 3020 or AC Delco CL88.
How bad does it smoke?? What color is the smoke?? I have a 1935 JD-B that I know has not had the head off or rings etc in at least 50 year and I don't have much trouble with the plugs. Mine is a 1935 and I run 50W oil in it, only use it in the summer and I use auto lite 3077 in it but I don't think your would use that plug because of tread size. Mine does smoke and uses oil but I'll not open it up till I just plain have to because it was my grand fathers and I hope to keep it as he left it years ago
Hobby farm
i had the same trouble on my jd b cut 2 loads of of wood on the buzz saw and youd have to change plugs all i do is add lead to it havent fouled a plug since. cant get that tractor warmed up never been over 130 degrees got a cyclone radiator and fan on a handstart just keeps it too cool
